[mapguide-users] Help with SID files
George McLean gmclean at gorge.net
Fri May 4 18:24:52 EDT 2007
I am having some trouble using Sid files in MGOS 1.1
I have installed the patches from http://home.gdal.org/mapguide
(mg_fdogdal.zip and mg_mrsid_110.zip).
I am building the map using Autodesk Mapguide Studio.
I have the Sid files and associated sdw and aux files in a single folder
on the machine running mapguide server.
I create a new data connection and choose the OSGeo FDO Provider for
Raster. In the definition form I added the path for the
DefaultRasterFileLocation under connection properties. No username or
password. Under data files I added the Sid file.Test Connection works
and I can save the definition of the feature source.
When I try to create a layer using this data source, I can add the data
source but I can not see the image in the layer preview or when I add it
to a map used in a web layout. I have tried loading the sdw and aux file
into the feature resource definition form but I get the same result.
I can see the images using Autocad Map or Arcview. Any suggestions?
George McLean
