[mapguide-users] Creating Layer in runtime
Kenneth ks at geograf.dk
Mon May 7 03:32:21 EDT 2007
I have not tried that sample, so i cannot help you there.
However, when I refered to the MapGuide Developer Guide, it states that
you have to export an xml for the Layer, and then write it into the
session repository.
If you try that, please remember that the Xml parser in MapGuide ONLY
accepts utf-8, and that Map Studio REQUIRES spaces between the Xml tags.
It might be fixed in a future release, but at least that is how 1.1.0 works.
Regards. Kenneth, GEOGRAF A/S
Deepak Kumar wrote:
> Hi,
> I am trying the devguide sample
> http://localhost:8008/mapguide/modifying_maps_and_layers/create_new_point_la
> yer_definition.php?SESSION=33bc71c6-0000-1000-8000-0000000044fd_en
> and getting the following error:
> ?ERROR: The new XML document is invalid.
> Please help me to solve the problem.
> Regards
> Deepak Kumar
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Kenneth
> Sent: Wednesday, May 02, 2007 10:49 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Creating Layer in runtime
> Hi Kumar.
> There is sample code for that particular functionality in the MapGuide
> Developer Guide, which is installed by default.
> If you run MapGuide under windows, you should be able to open the Guide
> from the start menu program group.
> Regards, Kenneth, GEOGRAF A/S.
> Deepak Kumar wrote:
>> HI,
>> How to create layers and then add location in run time.
>> Please provide some example.
>> Thanks
>> Deepak Kumar
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070507/b4e17eb9/attachment.html
