[mapguide-users] Convert lat lon to UTM
Brad Nesom kidsmake6 at msn.com
Tue May 8 21:38:43 EDT 2007
I am pretty sure you would have to have some reference to the zone as in a
polygon file with the zones. If you have esri products they are found in the
reference systems folder.or
http://www.geographynetwork.com/data/download/esri/utmzone.zip
Brad
Is there a way to convert a lat lon to UTM and extract the zone, northing,
and easting? I have a form where the user enters a position either by
clicking on the map or by manually entering the coordinates. The map is in
BC Albers. They can also manually enter the UTM zone, northing, and easting
instead of the lat lon.
On the database side, it would be nice to convert what the user entered so I
can put both (lat,  lon) and (UTM zone, northing, easting) in the database.
_________________________________________________________________
Now you can see trouble…before he arrives
http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_protection_0507
