[mapguide-users] Selection problem in AJAX with MySQL data (MGOS 1.0.2)
peter56 ibb.scigalla at arcor.de
Wed May 9 11:36:18 EDT 2007
... the problem is solved ... I have updated to 1.1 an it is running fine :-)
sorry - Peter
peter56 wrote:
> Hi all,
> following problem. When I try to select lines in the AJAX-Viewer then it
> is only a fortunate coincidence, that the proper element is shown
> (highlighted). Also when I click in an empty space ist sometimes an
> element selected and sometimes not.
> This behaviour I observe only in AJAX and with a MySQL database. Not in
> the DWF-viewer or with other elements (based on shp or sdf).
> I'm working with MGOS 1.0.2 and the OSGeo.MySQL.3.1 FDO. MySQL is Vers.
> 3.0.37 an the elements are stored as linestrings.
> Regards - Peter
View this message in context: http://www.nabble.com/Selection-problem-in-AJAX-with-MySQL-data-%28MGOS-1.0.2%29-tf3714340s16610.html#a10396765
