[mapguide-users] Re: need example to draw a line........
Chris Claydon chris.claydon at autodesk.com
Wed May 9 13:48:58 EDT 2007
There are a couple of things I can think of:
1)       Check that C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin
contains the necessary MapGuide DLL files (MapGuideDotNetApi.dll,
MgCoordinateSystem.dll etc.)
2)       Check that the folder "mapviewernet" is set up as an
application in IIS, and that it uses .NET version 2.
Chris.
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of veer pal
singh
Sent: May 9, 2007 11:41 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: need example to draw a line........
hi all,
 please solve my problem, i got this error on page---------
 how can i find namespace-------- "OSGeo.MapGuide"
Compilation Error
Description: An error occurred during the compilation of a resource
required to service this request. Please review the following specific
error details and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly
reference?)
Source Error:
Line 19: <%@ Import Namespace="System.Collections.Specialized" %>
Line 20: <%@ Import Namespace="System.IO" %>
Line 21: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 22:
Line 23: <script runat="server">int forDwf=0;</script>
Source File: C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewer
.aspx    Line: 21
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070509/275acc8c/attachment-0001.html
