[mapguide-users] RE: Resource was not found: Library://NewWebLayout.WebLayout
Chris Claydon chris.claydon at autodesk.com
Thu May 10 11:09:30 EDT 2007
>From the image you sent, it looks like you've downloaded the sample
application and attempted to modify it to use a different web layout.
The web layout you've entered in the aspx page does not exist in your
repository.
Chris.
  _____
From: veer pal singh [mailto:veerpal.jss at gmail.com]
Sent: May 10, 2007 4:39 AM
To: mapguide-users at lists.osgeo.org; Chris Claydon
Subject: Resource was not found: Library://NewWebLayout.WebLayout
hi sir,
      pleaze solve my problem i'm attaching my problem view.
      thanks & regards
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070510/37b2254a/attachment.html
