[mapguide-users] Tiled map using GETMAPIMAGE
Andy Morsell amorsell at spatialgis.com
Thu May 10 12:21:22 EDT 2007
Forgot the link, here it is:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc13
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, May 10, 2007 4:37 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Tiled map using GETMAPIMAGE
i believe mapguide 1.20 allows configurable tile sizes
z
On 5/10/07, Brendan Cervin <bcervin at gmail.com> wrote:
> Hello velen,
> I stumbled across your mapguide-users enquiry regarding point labeling
> with GETMAPIMAGE. I have made a custom cache for use with my own
> interface, with the exact same problem.
> I wondered if you had a solution to this, or if you live with the
> problem like I do. Here are some thoughts of mine on a solution.
> Use the GETTILEIMAGE command, the drawbacks are, you are limited to
> mapguides positioning, and a hardcoded tile size of 300x300 (which is
> my tile size anyway). This is only available as a PNG as far as I
> know, which I don't like.
> The new 1.2 mapguide is supposed to have several improvements in this
> area, so that could be worth waiting for.
> I have tried playing with base layers to force nice labeling..
> unsuccessfully.
> I have made my image request to GETMAPIMAGE about 2000x2000 pixels to
> limit the occurance of this problem..
> If you have any thoughts on this, please get back to me.
> Cheers, Brendan.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
