[mapguide-users] Creating maps at runtime
Kenneth ks at geograf.dk
Fri May 11 05:43:47 EDT 2007
Yes, they can.
I suppose you want to use digitizing to determine initial zoom.
The most simple approach, would be to make a map and a layout that looks
close to what you want.
Then export both from studio, using "Save as xml...".
When generating a new map/layout, you simply load the xml files, modify
them and save them back into the server (library or session, as you like).
Regards, Kenneth, GEOGRAF A/S
Kneo wrote:
> Hi,
> If we have a set of layers in the repository, can the map be created at
> runtime using the digitizing functions ? We would be having a lot of layers
> in our repo. We are planning to provide an interface to the user to select a
> set of these layers and internally the map and the web layout would be
> created automatically. This map and web layout would then be shown to the
> user
> Kneo
