[mapguide-users] KING FDO X, Y data does not show
Haris Kurtagic haris at sl-king.com
Mon May 14 14:50:22 EDT 2007
If I understand you correctly you got the FDO Class but you cannot see
it in the map.
Have you tried to setup MAP extend manually ( not in Layer preview )
In such cases I usually use Fdo2Fdo tool to check if provider is reading
data correctly from database
and also you can check what spatial extent is returned by provider.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Techswami
Sent: 14. maj 2007 7:40
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] KING FDO X, Y data does not show
i have tried all the instructions from the king FDO site to create FDO
class
and point data table in oracle  i could not see the point for  X, y
coordinates on the map. i my coordinates are in state plane .
e.g
 x:- 6144163.577635841
y:- 2106410.0770160034
anyone worked on same issue.
please let me know
tony
View this message in context:
http://www.nabble.com/KING-FDO--X%2C-Y-data-does-not-show-tf3746252s1661
0.html#a10564643
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
