[mapguide-users] Can't insert feature into certain SDFs
Takashige Nakagawa ta-nakagawa at apptec.co.jp
Wed May 16 08:27:00 EDT 2007
Hi all.
I've been testing my code which insert features into SDFs and it worked well
so far.
When it comes to certain SDFs, however, it wouldn't work.
I can delete and update features of these SDFs, so "Read Only" issue seems
not to have anything with this problem.
All properties are nullable except one described below.
<xs:element name="FeatId">
<xs:simpleType>
<xs:restriction base="fdo:int32" />
</xs:simpleType>
</xs:element>
This is the key field to the feature. I assume the case of this problem is
that this field value is not "auto-generated",
because when the key field is like :
<xs:element name="Autogenerated_SDF_ID" fdo:readOnly="true" minOccurs="0"
fdo:autogenerated="true">
<xs:simpleType>
</xs:simpleType>
<xs:annotation>
<xs:documentation>Autogenerated identity property</xs:documentation>
</xs:annotation>
</xs:element>
I tried to set the key field into "auto-generated" by
"MgDataPropertyDefinition::SetAutoGeneration() " method, but I couldn't make
it so.
Does anyone know how to solve this problem?
Any information is appliciated.
Thanks in advance.
T.Nakagawa
Regards.
