[mapguide-users] RE: Informix database support
Dave Wilson dave.wilson at autodesk.com
Fri May 18 10:18:06 EDT 2007
Did you specify a coordinate system that corresponds with your X/Y or
geometry columns? I'm guessing you have. Was the key column for the
table you are trying to use defaulted or did you have to select it? I'm
not familiar with Informix so I don't know if there are any special
parameters you might need to include in the connection string.
I don't' have an Informix database to test against so sending the driver
will be of limited value other than to see the interface via the ODBC
Admin.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
Sent: Friday, May 18, 2007 1:02 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Informix database support
I have only tried a DSN based connection. With this connection I can see
the
database tables in the studio but the geometries are not shown in the
map.
Also when I try to perform a get for e.g. a filter it returns a FDO
error.
Currently I am not in the office but I can send the driver used and the
exact error message afterwards.
Thanks in advance for the support.
Dave Wilson-3 wrote:
> I assume you have a driver for this? Did you try both a DSN and a
> Connection string based connection?
> Regards,
> Dave
> From: mapguide-users-bounces at lists.osgeo.org
Cams
> Sent: Thursday, May 17, 2007 6:46 AM
> Subject: [mapguide-users] Informix database support
> Hello all,
> it seems to be it is not possible to connect to an Informix database
> with
> the ODBC provider. Is it planned to have the informix database
supported
> in
> the future ?
http://www.nabble.com/Informix-database-support-tf3771742s16610.html#a10
> 663521
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
677424
