[mapguide-users] Navigation Example .NET
Andy Morsell amorsell at spatialgis.com
Fri May 18 12:38:48 EDT 2007
The execution of the API functions must happen server side in this instance.
But, it looks like you could put your .NET conditional code in the
gotopoint.aspx page and it would work.  The OnPageLoad() javascript function
would fire afterwards so all should behave smoothly.  And, you would not
have to programmatically refresh the map since that will happen with the
ZoomToView anyway.
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Friday, May 18, 2007 9:28 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Navigation Example .NET
Thanks for the response.  I am looking for a way to achieve this on the
client side. I do not want to check until after the user has clicked on
link. (such as putting it in the gotopoint.aspx page). Will this work here?
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Friday, May 18, 2007 11:40 AM
To: 'MapGuide Users Mail List'
You should be able to use the MgLayer::IsVisible function to check the
visibility and then SetVisible to turn it on.  You will then have to refresh
the map to reflect the change.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
Sent: Friday, May 18, 2007 8:00 AM
Subject: [mapguide-users] Navigation Example .NET
Anyone know how I would go about checking to see if a layer was on in the
navigation example and if it is not turn it when clicking a link.
Thanks!
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070518/ea2ab0a8/attachment.html
