[mapguide-users] Re: Memory Issues 1.20beta2 with King Oracle v0.6.5
Zac Spitzer zac.spitzer at gmail.com
Sat May 19 13:03:43 EDT 2007
Just ran up mapguide 1.10 in a clean vmware image to compare
I found that the mem usage would be released and drop back down,
there still was 30Mb of virtual memory being added with each map
refresh.
I'm on XP here btw
On 5/20/07, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> I have just spent the last 12 hours getting a cold fusion / cfmx
> wrapper on the java API
> going to the point i can mimic the schema report (php geometry
> previewer) in the latest beta.
> Anyway, now that i got that going, i started to test an oracle spatial
> layer. I am using
> a web/map/layer in session resource. The dataset are the state
> polygons for australia, which contains 12813 records (27 MB in shp
> files).
> Each time I fresh the map, mapguide adds another 30mb ram and 30mb
> which doesn't get released
>                                         RAM             VM              CPU Time
> Start Service                   35              31              0.01
> Load Preview(CF)*               48              41              0.01
> Load Map                                123             117             0.27
> Load Map                                155             152             0.52
> Load Map                                188             187             1.18
> Load Map                                221             221             1:44
> Load Preview(PHP)               221             221             forgot to write it down :)
>   Count Features**              255             257             2.10
> Load Map                                287             291             2.37
> *I checked this out and the memory increase only occurs for me on the
> first request, it's not CFMx or the Java API, subsequent requests
> might increase a little but it settles down.
> ** The schema report does a geometry count using
> $featureReader = $featureSrvc->SelectFeatures($featuresId, $className, null);
>                                 while($featureReader->ReadNext())
>                                         $totalEntries++;
> which ends up loading the whole record set into mapguide, which
> doesn't get re-used when the map is rendered either.
> I looked in the API round MgFeatureReader but i couldn't find any
> reference to a getRowCount/Recordcount/Length functionality in there
> doesn seem to be one.
> I guess you could use MgFeatureService::ExecuteSqlQuery with count(*)
> but it's late and i'm too tired,  the feature capabilities would let
> you find out.
> I think it would be good for the api to have a recordcount function,
> event if it's wrapping
> MgFeatureService::ExecuteSqlQuery('select count(*)from table") but i
> don't know much about the innards of FDO world.
> So back to the memory stuff. I tried the Tasmanian SHP file in
> mapguide which is about 8mb / 5886 rows (complex coastlines and they
> are provided state by state),
> i kept them as SHP ( i found the speed of SHP/SDF to be quite similiar
> BTW) and as usual it's a lot faster in SHP land than Oracle and the
> memory is released after the map is rendered. The CPU usage for with
> SHP nothing compared to the Oracle ( and the oracle process was very
> low)
> I am using King Oracle v0.6.5 with 10g2 10.2.0.3, looks like it's got
> a memory leak in there somewhere.
> After about 15 refreshes of the map, memory hits over 600Mb and the
> same in virtual memory. At which point it the mapguide service doesn't
> respond anymore and kill from task manager is needed. there is nothing
> in the mapgiode error log either.
> Zac Spitzer
> http://zacster.blogspot.com/
> +61 405 847 168
Zac Spitzer
+61 405 847 168
