[mapguide-users] Navigation Example .NET
Berdel, Brian brian.berdel at mcmtrans.com
Mon May 21 11:12:30 EDT 2007
Looks like you are right...Thanks.  I cannot seem to find your
workaround, can you send me a link or something?
Thanks,
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Monday, May 21, 2007 9:58 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Navigation Example .NET
The zoom will invalidate the map, and is the same as a refresh.
I haven't tested it, but I don't think a scale change (eg. zoom) will
refresh the visible layer cache, but it might.
Regards, Kenneth, GEOGRAF A/S
Andy Morsell wrote:
But in the example below, where the layer is being set to visible right
before a zoom, the zoom should take care of the map refresh and the
layer should appear on the subsequent map.  Or, is this not the case?
Andy
Sent: Sunday, May 20, 2007 11:18 AM
If you modify the layer visibility, using serverside code, it will not
work correctly with the AJAX viewer.
The problem is that the AJAX client has a small cache of visible layers,
and calling map.refresh() on the client does not invalidate this cache.
The symptoms will be that no tooltip is displayed for the layer, and the
layer never shows up in the legend.
I've posted this bug on the mapguide-internals list, and a workaround.
Regards. Kenneth, GEOGRAF A/S
Berdel, Brian wrote:
Cool, thanks! I'll give it a try.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Friday, May 18, 2007 12:39 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Navigation Example .NET
The execution of the API functions must happen server side in this
instance.  But, it looks like you could put your .NET conditional code
in the gotopoint.aspx page and it would work.  The OnPageLoad()
javascript function would fire afterwards so all should behave smoothly.
And, you would not have to programmatically refresh the map since that
will happen with the ZoomToView anyway.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Friday, May 18, 2007 9:28 AM
Thanks for the response.  I am looking for a way to achieve this on the
client side. I do not want to check until after the user has clicked on
link. (such as putting it in the gotopoint.aspx page). Will this work
here?
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
Morsell
Sent: Friday, May 18, 2007 11:40 AM
You should be able to use the MgLayer::IsVisible function to check the
visibility and then SetVisible to turn it on.  You will then have to
refresh the map to reflect the change.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Brian
Sent: Friday, May 18, 2007 8:00 AM
Subject: [mapguide-users] Navigation Example .NET
Anyone know how I would go about checking to see if a layer was on in
the navigation example and if it is not turn it when clicking a link.
Thanks!
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070521/07a33514/attachment-0001.html
