[mapguide-users] Navigation Example .NET
Andy Morsell amorsell at spatialgis.com
Mon May 21 17:54:37 EDT 2007
The JavaScript call should be GetMapFrame().Refresh();
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Monday, May 21, 2007 2:43 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Navigation Example .NET
Why do I keep getting?
Object doesn't support this property or method when referring to
parent.GetMapFrame().Refresh;
I have this in an onload function of the page in JavaScript.
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Monday, May 21, 2007 2:33 PM
Subject: Re: [mapguide-users] Navigation Example .NET
I can't find it either :D...
Here is the text of my post:
<snip>
When using the server API for altering layer visibility, a call to the
GetMapFrame().Refresh() is not sufficient to refresh the legend.
Pseudocode:
$map.Open(...);
$map.Layers('layername').setVisibility(true);
$map.Save();
Calling the GetMapFrame().Refresh() after this, will update the map to
display the new layer.
However the Legend does not reflect this change.
The problem can be solved with two changes:
1. In ajaxmappane.templ, the Refresh() function should also call
ResetVisLayers()
2. In legendctrl.templ, the Refresh call should be changed, so it does
not call with the summary parameter
The problem only occurs in the AJAX viewer.
When retrieving the legend script, using the summary parameter, the
visibility does not change.
Removing the summary parameter is a bad fix, as it also disables the
optimizations that the summary parameter gives.
If the above mentioned fix 1, is not implemented, a lot of features will
fail after modifying the map.
For instance tooltips for the layers will not work.
I think this is a problem with a design flaw in the way the viewer is
implemented.
Keeping state data solely on the client is a very bad idea.
This happens with layerstates and current zoom in the AJAX viewer, and
the Selection in the DWF viewer.
To allow modifications to the map from the server API, all data should
be written to the server.
To provide caching the client should fetch a change list, rather than
sporadically caching data.
Using a sequence number, the client can skip multiple update cycles, and
still be synced correctly.
Using a generic format would allow the DWF and ajax viewer to work on
exactly the same data, thus reducing duplicate code.
</snip>
Regards, Kenneth, GEOGRAF A/S
Berdel, Brian wrote:
Looks like you are right.Thanks.  I cannot seem to find your workaround, can
you send me a link or something?
Thanks,
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
  _____
Sent: Monday, May 21, 2007 9:58 AM
The zoom will invalidate the map, and is the same as a refresh.
I haven't tested it, but I don't think a scale change (eg. zoom) will
refresh the visible layer cache, but it might.
Andy Morsell wrote:
But in the example below, where the layer is being set to visible right
before a zoom, the zoom should take care of the map refresh and the layer
should appear on the subsequent map.  Or, is this not the case?
Andy
  _____
Sent: Sunday, May 20, 2007 11:18 AM
If you modify the layer visibility, using serverside code, it will not work
correctly with the AJAX viewer.
The problem is that the AJAX client has a small cache of visible layers, and
calling map.refresh() on the client does not invalidate this cache.
The symptoms will be that no tooltip is displayed for the layer, and the
layer never shows up in the legend.
I've posted this bug on the mapguide-internals list, and a workaround.
Regards. Kenneth, GEOGRAF A/S
Cool, thanks! I'll give it a try.
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Friday, May 18, 2007 12:39 PM
To: 'MapGuide Users Mail List'
The execution of the API functions must happen server side in this instance.
But, it looks like you could put your .NET conditional code in the
gotopoint.aspx page and it would work.  The OnPageLoad() javascript function
would fire afterwards so all should behave smoothly.  And, you would not
have to programmatically refresh the map since that will happen with the
ZoomToView anyway.
Andy
  _____
Sent: Friday, May 18, 2007 9:28 AM
Thanks for the response.  I am looking for a way to achieve this on the
client side. I do not want to check until after the user has clicked on
link. (such as putting it in the gotopoint.aspx page). Will this work here?
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
  _____
Sent: Friday, May 18, 2007 11:40 AM
You should be able to use the MgLayer::IsVisible function to check the
visibility and then SetVisible to turn it on.  You will then have to refresh
the map to reflect the change.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
Sent: Friday, May 18, 2007 8:00 AM
Subject: [mapguide-users] Navigation Example .NET
Anyone know how I would go about checking to see if a layer was on in the
navigation example and if it is not turn it when clicking a link.
Thanks!
Brian Berdel
p: 215.283.9444
www.mcmtrans.com
  _____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
  _____
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070521/0ae7a30c/attachment-0001.html
