[mapguide-users] MySQL connection error - unsupported buffer type?
Dhirendra Kumar dhirendra.mgos at gmail.com
Tue May 22 08:08:30 EDT 2007
Hi Kevin,
I read your message that you succesfully connect MGOS with MySQL 5.0. I also
want to connect with MySQL but i have not idea where i get FDO 3.2 and how
to install it. In my next project i have to use MySQL as a Database for
runtime layer creation but till now i have not idea. You succesfully connect
with MySQL so, please help me. If you can send any Example or Query feature
then i'll get more help. I am waiting for your replay. Please Help me.
Thankyou in Advance.
Regards,
Dhirendra Kumar
kgrootendorst wrote:
> Hello,
> Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
> I have success with setting up a MySQL connection for an application on my
> local drive.
> Now that I have 'moved' the application to a remote server, I am running
> into a mysql connection error.  I can't seem to find anyone with a similar
> problem, nor have I been able to resolve the error with any success. Below
> is a dump from the server log.  Does anybody have any ideas?
> Error: An exception occurred in FDO component.
>         RDBMS: Using unsupported buffer type: 0  (parameter: 1)
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute line 103 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open line 815 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Thanks in advance.
> Kevin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MySQL-connection-error---unsupported-buffer-type--tf3675443s16610.html#a10736489
