[mapguide-users] About FDO
Andy Morsell amorsell at spatialgis.com
Tue May 22 11:11:09 EDT 2007
What you describe is not really a function of FDO but rather of the MapGuide
API.  If you just need to update layer properties and refresh the layer and
map, then it doesn't matter what your feature source type is.  Any database
(that supports your geometry types) will work fine for this type of
application.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra Kumar
Sent: Monday, May 21, 2007 10:45 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] About FDO
Hi All,
I want to use FDO connectivity with MySQL or Oracle. So, first i want to
know some information about FDO when i shall use Oracle with FDO then during
run time FDO direct Connect Oracle Database ? I am asking this Qustion
because my client requirments is to change layers property during run time,
Co'uz they want to update Database time to time and as per updation they
want to show features on map. Is it possible with FDO ? if yes then tell me
which database is more sutable with MGOS ? and posible then send me some
Examples of FDO Connectvity with some Quieries Example.
Thankyou in Advance,
Regards,Dhirendra Kumar
View this message in context:
http://www.nabble.com/About-FDO-tf3794354s16610.html#a10731856
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
