[mapguide-users] Adventures In Theming
Ronnie Louie ronnie.louie at autodesk.com
Tue May 22 11:21:10 EDT 2007
Hi James,
This is a known defect and has been logged at
http://trac.osgeo.org/mapguide/ticket/146.
Ronnie
-----Original Message-----
Sent: Monday, May 21, 2007 3:52 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Adventures In Theming
We have a layer in MapGuide OS 1.2 Beta 2 that is themed on a field from
a
joined table. The tool-tip and the labels for that layer are also based
on
the same field from the joined table. The field definition for the
tool-tip, the labels, and the theme categories is exactly the same in
each
place.
The tool-tip always displays the correct data, but the theming and the
label both display data from some other record in the joined table.
Panning the map causes the labels and the theme to change randomly --
that
is: the record the label and theming are based on varies randomly with
each pan operation.
This is true whether using the the original SHP file as the spatial
datasource, or using an SDF that Studio created from the SHP. The joined
table is in an Access database located in the repository (where the
Migration Wizard placed it).
Is anyone else having problems with joined tables?
James Card
California CAD Solutions, Inc.
209 578-5580
