[mapguide-users] list selection example in c#
Micha Lehmann paradoxe_vogelkunde at yahoo.de
Wed May 23 05:06:15 EDT 2007
hi there,
i want to use the listajaxselection.php example from the
developersguide, but i want to change it into c# syntax.
until line 64 its no big deal, but then i have problems, php is :
$layers = $selection->GetLayers();
       if ($layers)
         for ($i = 0; $i < $layers->GetCount(); $i++)
           // Only check selected features in the Parcels layer.
           $layer = $layers->GetItem($i);
           if ($layer && $layer->GetName() == 'Parcels')
             // Create a filter containing the IDs of the selected
features on this layer
             $layerClassName = $layer->GetFeatureClassName();
             $selectionString = $selection->GenerateFilter($layer,
$layerClassName);
             // Get the feature resource for the selected layer
             $layerFeatureId = $layer->GetFeatureSourceId();
             $layerFeatureResource = new
MgResourceIdentifier($layerFeatureId);
             // Apply the filter to the feature resource for the
selected layer. This returns
             // an MgFeatureReader of all the selected features.
             $queryOptions->SetFilter($selectionString);
             $featureReader =
$featureService->SelectFeatures($layerFeatureResource, $layerClassName,
$queryOptions);
             // Process each item in the MgFeatureReader, displaying the
owner name
             while ($featureReader->ReadNext())
               $val = $featureReader->GetString('NAME') . '<br
/>&nbsp;&nbsp;' . $val = $featureReader->GetString('RPROPAD');
               echo $val . '<br />';
       else
       echo 'No selected layers';
       echo '</p>';
maybe you could help me a little bit !
Thanks
Micha
View this message in context: http://www.nabble.com/list-selection-example-in-c--tf3802759s16610.html#a10760071
