[mapguide-users] RE: MySQL connection error - unsupported buffer type?
Dhirendra Kumar dhirendra.mgos at gmail.com
Wed May 23 07:36:59 EDT 2007
Hi Andy Morsell,
As per your Suggestion i installed MySQL 5.0 and try to make connection with
MySQL using Autodesk studio 2007 but i get one error:- An exception occured
in FDO component. The runtime was not found (module LIBMYSQL.dll). i also
copied libmySQL.dll file from MySQL directory to Server\bin\FDO and
server\bin directory but still error is same, now please tell me what i do ?
I am  using MGOS 1.1.0 version. Please suggest me........
Thankyou in Advance
Regards,
Dhirendra Kumar
Andy Morsell wrote:
> If you install MapGuide Open Source, it includes FDO.  You do not need to
> worry about downloading, installing or configuring FDO separately.  In
> MapGuide Studio, just choose the MySQL or ODBC data providers when
> creating
> a feature source and then point that to your MySQL database.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Tuesday, May 22, 2007 5:09 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MySQL connection error - unsupported buffer
> type?
> Hi Kevin,
> I read your message that you succesfully connect MGOS with MySQL 5.0. I
> also
> want to connect with MySQL but i have not idea where i get FDO 3.2 and how
> to install it. In my next project i have to use MySQL as a Database for
> runtime layer creation but till now i have not idea. You succesfully
> connect
> with MySQL so, please help me. If you can send any Example or Query
> feature
> then i'll get more help. I am waiting for your replay. Please Help me.
> Thankyou in Advance.
> Regards,
> Dhirendra Kumar
> kgrootendorst wrote:
>> Hello,
>> Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
>> I have success with setting up a MySQL connection for an application
>> on my local drive.
>> Now that I have 'moved' the application to a remote server, I am
>> running into a mysql connection error.  I can't seem to find anyone
>> with a similar problem, nor have I been able to resolve the error with
>> any success. Below is a dump from the server log.  Does anybody have any
> ideas?
>> Error: An exception occurred in FDO component.
>>         RDBMS: Using unsupported buffer type: 0  (parameter: 1)
>>  StackTrace:
>>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\
> feature\FeatureServiceHandler.cpp
>>   - MgOpTestFeatureSourceConnection.Execute line 103 file
> feature\OpTestFeatureSourceConnection.cpp
>>   - MgFdoConnectionManager.Open line 815 file
>> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\com
>> mon\manager\FdoConnectionManager.cpp
>> Thanks in advance.
>> Kevin
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MySQL-connection-error---unsupported-buffer-type--tf36
> 75443s16610.html#a10736489
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/MySQL-connection-error---unsupported-buffer-type--tf3675443s16610.html#a10762123
