[mapguide-users] OGR and MGOS
Traian Stanev traian.stanev at autodesk.com
Wed May 23 10:28:28 EDT 2007
I had forgotten to check in the last fix (for S57 files) until 5 minutes
ago. Anyway, a dll containing that fix and with no manifest is also
posted at:
http://download.osgeo.org/fdo/3.2.2-Beta2/
This is based on Fdo 3.2.2, Proj 4.5.0, GDAL 1.4, GEOS 2.2.3. It also
has OCI support and GML/INTERLIS support compiled in, so it's a big dll.
Also, I compiled with Visual Studio Service Pack 1, so I don't know how
that will affect things. This is the only VS version I have.
It's nice to have choice though, Kenneth has posted builds with versions
that I no longer have.
Anyway, I am aware of one more bug that needs fixing soon and it has to
do with adding support for UTF8 conversion to handle international
character sets in PostGIS.
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Wednesday, May 23, 2007 9:50 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] OGR and MGOS
I have built and posted providers for FDO 3.2 (MgOS 1.1) and FDO 3.1
(MgOS 1.0 and MgEP 1.0 + SP1).
The providers are built without Oracle support, using the latest OGR
provider code from Traian.
The manifest has been removed from these, hopefully fixing a few
problems.
Download and use, is on your own risk. I provide no support for them.
http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.2 - Proj 4.5.0 -
GDal 1.3.2 - Geos 2.2.3 - No OCI.zip
http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.1 - Proj 4.5.0 -
Regards, Kenneth, GEOGRAF A/S
Traian Stanev wrote:
The 3.2.2 build will not work with MapGuide 1.1, it is compiled for
MapGuide 1.2. You need to try an older build of the DLL (3.2 perhaps?)
or wait for MapGuide 1.2.
There is another problem that may cause connection properties to not
show up, which someone on this list traced to manifest issues in the
dll. I hope to have a build of the dll without manifest (and with the
fix for S57 files) posted some time soon. It will be a 3.2.2 build.
In any case, I believe you have the first problem -- your OGR provider
build is too new.
Traian
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Rahul
	Sent: Tue 5/15/2007 6:52 AM
	Cc:
	Subject: RE: [mapguide-users] OGR and MGOS
	         I tried to configure  OGR Provider 3.2.2_beta1 with
MapGuide Open Source 1.1.0 ,Finally when i tried to connect the database
using the OGR Provider(Using Map Guide Studio) I unable to get the
Connection Properties in the Editior,Like DataSource & ReadOnly etc
.Kindly refer to the screen shots.
	Thks
	Max
	Chris Gountanis <cgountanis at mpower-tech.com>
<mailto:cgountanis at mpower-tech.com>  wrote:
		Using this download:
http://download.osgeo.org/fdo/3.2.2-Beta1/OGRProvider-3.2.2_beta1.win32.
zip
		Put the OGRProvider.dll in C:\Program
Files\MapGuideOpenSource\Server\Bin\FDO\
		Edited the C:\Program
Files\MapGuideOpenSource\Server\Bin\FDO\providers.xml
		Added:
		  <FeatureProvider>
		    <Name>OSGeo.OGRProvider.3.2</Name>
		    <DisplayName>OSGeo FDO Provider for ArcSDE
</DisplayName>
		    <Description>Read/write access to an ESRI
ArcSDE-based data store, using Oracle and SQL Server. </Description>
		    <IsManaged>False</IsManaged>
		    <Version>3.2.2_beta1</Version>
<FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
		    <LibraryPath>OGRProvider.dll</LibraryPath>
		  </FeatureProvider>
		I copied the FeatureProvider from above "ArcSDE". Once I
updated the DisplayName and Description to something like
<DisplayName>OSGeo FDO Provider for OGR </DisplayName> it worked great J
		Chris
		________________________________________
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
		Sent: Friday, May 11, 2007 1:59 PM
		Edit providers.xml and then restart the server (I assume
you put the DLL in the /FDO/bin that belongs to the server). Then it
should show up in Studio. If it does not, check the dll dependencies
using depends or something...
		As far as Write goes, it depends what you mean by write.
Insert, Update, Delete, Create Layer?
		Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
		Sent: Friday, May 11, 2007 2:48 PM
		To: 'MapGuide Users Mail List'
		OK I grabbed this version
zip what is the proper procedure. I edited the provider.xml file. Same
exact thing I did for Map 2008 and it worked.
		Also is there a Read/Write solution to OGR?
		Chris
Stanev
		Sent: Friday, May 11, 2007 1:41 PM
		In Studio, create a New Data Connection. It will show a
list of providers including the OGR provider. When you press on that, it
will bring up a connection editor dialog that lets you set the OGR
connection string. If the provider does not show up in the list, then it
is not installed correctly on the server.
		Traian
Gountanis
		Sent: Friday, May 11, 2007 2:17 PM
		Subject: [mapguide-users] OGR and MGOS
		I have used the OGR in Map 2008 just fine. I want to
know how to use the OGR FDO in MapGuide OS. Studio won't show the data
type. Do you have to set the resource manually using the web tier? If so
what is an example of the XML?
		Thanks!
		Chris
		mapguide-users mailing list
		mapguide-users at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
	You snooze, you lose. Get messages ASAP with AutoCheck
<http://us.rd.yahoo.com/evt=47959/*http:/advision.webevents.yahoo.com/ma
ilbeta/newmail_html.html>
	in the all-new Yahoo! Mail Beta.
  _____
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070523/68dc7a47/attachment.html
