[mapguide-users] .Net and Debugging
Berdel, Brian brian.berdel at mcmtrans.com
Wed May 23 13:38:42 EDT 2007
I get 404 cannot be found for the viewer if I use a default.aspx page as
my start page.  I switched that to use IIS
http://localhost/mapguide/dotnetviewersample
Because I have dotnetviewersample configured under Mapguide in IIS and
when I use F5 it takes we me to http://localhost:3467/dotnetviewersample
I am assuming that is why it cannot find the viewer files.
And I 1st cannot start debugger because windows authentication is not
configured...So I configured Windows Authentication and it the error
reads there is an authentication error. I have seen a lot of errors
related to Vista and this, but I am using XP.
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Wednesday, May 23, 2007 12:12 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] .Net and Debugging
What error do you get when you try the traditional debug method?
Greg
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Wednesday, May 23, 2007 11:58 AM
I guess I didn't try every way...Attaching to the aspnet_wp.exe works,
but I cannot debug using F5
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
Brian
Sent: Wednesday, May 23, 2007 11:48 AM
Subject: [mapguide-users] .Net and Debugging
I have had trouble with this since I started with MapGuide...I have
tried every possible debugging method in .Net and I cannot Debug.
Has anyone else had this issue and if so have you been able to fix it?
Development Machine is XPSP2 / VS 2005 / Mapguide 1.2
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Wednesday, May 23, 2007 11:37 AM
Subject: Re: [mapguide-users] OGR and MGOS
I haven't tried that one. Basically, check the OGR website for what is
supported.
I have removed some of the dependencies that Traian includes, as I don't
have them (OCI mainly, can't remember the others).
Regards, Kenneth, GEOGRAF A/S
Jose Manuel C G wrote:
> Thk for the providers, Kenneth.
> Does support WMS with 'queryable' layer?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
