[mapguide-users] .Net and Debugging
Berdel, Brian brian.berdel at mcmtrans.com
Wed May 23 13:41:18 EDT 2007
They are all checked. Thanks though. That is not the problem, it is that
I can start the project but I keep getting 404 cannot be found error for
the viewer, no matter how I attempt to set the link.
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori
Maleski
Sent: Wednesday, May 23, 2007 1:40 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] .Net and Debugging
MS Visual Studio 2005 Pro
Tools > Options > Debugging > Just-In-Time
Check all options.
This will allow debugging (F5) to break on MapGuide code when an error
is
encountered.
You cannot pause or set break points on the MapGuide code with this
method,
only break and view errors when encountered.
Cheers,
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Wednesday, May 23, 2007 8:58 AM
To: MapGuide Users Mail List
I guess I didn't try every way...Attaching to the aspnet_wp.exe works,
but I cannot debug using F5
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
Brian
Sent: Wednesday, May 23, 2007 11:48 AM
Subject: [mapguide-users] .Net and Debugging
I have had trouble with this since I started with MapGuide...I have
tried every possible debugging method in .Net and I cannot Debug.
Has anyone else had this issue and if so have you been able to fix it?
Development Machine is XPSP2 / VS 2005 / Mapguide 1.2
Brian  Berdel
p: 215.283.9444
www.mcmtrans.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Sent: Wednesday, May 23, 2007 11:37 AM
Subject: Re: [mapguide-users] OGR and MGOS
I haven't tried that one. Basically, check the OGR website for what is
supported.
I have removed some of the dependencies that Traian includes, as I don't
have them (OCI mainly, can't remember the others).
Regards, Kenneth, GEOGRAF A/S
Jose Manuel C G wrote:
> Thk for the providers, Kenneth.
> Does support WMS with 'queryable' layer?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
