[mapguide-users] Compile mapguide-1.2.0 on Fedora Core 6
Manuel Ferreira manuel.ferreira at onlinehome.de
Wed May 23 10:03:09 EDT 2007
Hi all,
I have successfully built Apache, PHP, FDO and MapGuide-OEM on Fedora
Core 6 (gcc  4.1.1).
But I cannot compile the MapGuide-Server on Fedora Core 6:
make
GwsFeatureQueryResults.cpp:27:42: error: SDF/IScrollableFeatureReader.h:
No such file or directory
GwsFeatureQueryResults.cpp:28:42: error: SHP/IScrollableFeatureReader.h:
GwsFeatureQueryResults.cpp: In member function 'virtual EGwsStatus
CGwsFeatureIterator::InitializeReader(FdoIFeatureReader*, IGWSQuery*,
CGwsPreparedFeatureQuery*, bool)':
GwsFeatureQueryResults.cpp:75: error: expected type-specifier before
'SdfIScrollableFeatureReader'
GwsFeatureQueryResults.cpp:75: error: expected `>' before
GwsFeatureQueryResults.cpp:75: error: expected `(' before
GwsFeatureQueryResults.cpp:75: error: 'SdfIScrollableFeatureReader' was
not declared in this scope
GwsFeatureQueryResults.cpp:75: error: expected primary-expression before
'>' token
GwsFeatureQueryResults.cpp:76: error: expected `)' before
'm_extProviderType'
GwsFeatureQueryResults.cpp:77: error: expected type-specifier before
'ShpIScrollableFeatureReader'
GwsFeatureQueryResults.cpp:77: error: expected `>' before
GwsFeatureQueryResults.cpp:77: error: expected `(' before
GwsFeatureQueryResults.cpp:77: error: 'ShpIScrollableFeatureReader' was
make[4]: *** [GwsFeatureQueryResults.lo] Fehler 1
make[4]: Leaving directory
`/root/mapguide-1.2.0/Server/src/Gws/GwsQueryEngine'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory `/root/mapguide-1.2.0/Server/src/Gws'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/root/mapguide-1.2.0/Server/src'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/root/mapguide-1.2.0/Server'
make: *** [all-recursive] Fehler 1
I did't found the missing headers "SDF/scrollableFeatureReader.h" and
"SHP/scrollableFeatureReader.h" anywhere. Can anyone help me, please?
best regards
Manuel Ferreira
