[mapguide-users] MapGuide 1.2 Beta2, Login Error
Zac Spitzer zac.spitzer at gmail.com
Thu May 24 06:58:29 EDT 2007
visibility is good, i remember the early days of this mapguide before
it was open source, there was no trac for the beta testers...
please, if you can't find it, enter a bug
On 5/24/07, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> Yes, I searched that one.
> I figured it might be known, even though it is not on trac.
> Regards, Kenneth, GEOGRAF A/S
> Zac Spitzer wrote:
> > there is a trac project db @ http://trac.osgeo.org/mapguide/report
> >> After installing the MapGuide 1.2 Beta 2, I could not login to the
> >> MapGuide Site Admin. Tried restarting the server, but no change.
> >> Finally, I found out that the Installer had selected the wrong version
> >> of the .Net framework in IIS. Selecting the correct version on the top
> >> "mapguide" folder, fixed the login problem. Not sure why, since the site
> >> admin is running with php.
> >> Is it a know defect that the wrong version is selected?
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168
