[mapguide-users] RE: About FDO
Andy Morsell amorsell at spatialgis.com
Thu May 24 12:02:11 EDT 2007
To create data, data connections, layers, maps and so on it is easiest to
use one of the GUI's available.  MapGuide Open Source comes with Web Studio.
Or, you can use  the fully featured Autodesk MapGuide Studio.  You can
download and use a preview version from here:
http://usa.autodesk.com/adsk/servlet/index?id=7176611&siteID=123112
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra Kumar
Sent: Thursday, May 24, 2007 5:17 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: About FDO
Hi Andy Morsell,
Thankyou for your replay, I have succesfully establish mapguide connection
with MySQL 5.0. But i have not idea how to make layer using this connection
and define Cordinate system, So please guide me, how to make layers ? I am
waiting for your valuable replay.
Regards,
Dhirendra Kumar
Andy Morsell wrote:
> What you describe is not really a function of FDO but rather of the
> MapGuide API.  If you just need to update layer properties and refresh
> the layer and map, then it doesn't matter what your feature source
> type is.  Any database (that supports your geometry types) will work
> fine for this type of application.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> Kumar
> Sent: Monday, May 21, 2007 10:45 PM
> Subject: [mapguide-users] About FDO
> Hi All,
> I want to use FDO connectivity with MySQL or Oracle. So, first i want to
> know some information about FDO when i shall use Oracle with FDO then
> during
> run time FDO direct Connect Oracle Database ? I am asking this Qustion
> because my client requirments is to change layers property during run
> time,
> Co'uz they want to update Database time to time and as per updation they
> want to show features on map. Is it possible with FDO ? if yes then tell
> me
> which database is more sutable with MGOS ? and posible then send me some
> Examples of FDO Connectvity with some Quieries Example.
> Thankyou in Advance,
> Regards,Dhirendra Kumar
> http://www.nabble.com/About-FDO-tf3794354s16610.html#a10731856
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/About-FDO-tf3794354s16610.html#a10782569
