[mapguide-users] Locale, when using the MapGuide API
Hidekazu Shimaji hshimaji at ybb.ne.jp
Fri May 25 10:53:43 EDT 2007
Hello Kenneth,
Please try a SetLocale method of the MgUserInformation class.
It seems to work as you wish.
Regards,
Hidekazu
--- "Kenneth, GEOGRAF A/S" <ks at geograf.dk> wrote:
> I'm using the .Net API to create a new session for the user.
> This works fine, with the following code:
>         MapGuideApi.MgInitializeWebTier(extensionsDir + "webconfig.ini");
>         MgSiteConnection con = new MgSiteConnection();
>         con.Open(new MgUserInformation(username, password));
>         return con.GetSite().CreateSession();
> The returned string contains the session id.
> It keeps returning locale "en" in the session string.
> When using the Web API, the locale can be sent explicitly, but using the
> .Net API, there are only username and password arguments.
> How do I change the new session locale?
> Regards, Kenneth, GEOGRAF A/S
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
