[mapguide-users] MapGuide 1.2 Beta2, Login Error
Jason Birch Jason.Birch at nanaimo.ca
Fri May 25 11:57:52 EDT 2007
Brad wrote:
So on my mapguide virtual dir I should change from 2.0 back to 1.1 in
all cases? Or just in the case that I have an application built on 1.1?
It sounded as though this would fix my webstudio login problem.
I believe that this may have been fixed as part of ticket #137:
http://trac.osgeo.org/mapguide/ticket/137
You can apply the simple patch yourself to see if it helps:
http://trac.osgeo.org/mapguide/changeset/1739
Jason
