[mapguide-users] MySQL Database Feature Source Cordiante System
Andy Morsell amorsell at spatialgis.com
Mon May 28 13:41:47 EDT 2007
And, even with the new beta, my testing indicates that the coordinate system
override is not working for both MySQL native point geometry or FDO geometry
defined from lat lon fields.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, May 28, 2007 10:27 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MySQL Database Feature Source Cordiante System
As per my previous email unless you have the new MGOS beta there is no field
to specify a coordinate system override since currently MySQL doesn't
support coordinate systems in the native schema. You can specify the correct
coordinate system in your map but you will have to zoom and find the data to
set the extent yourself.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra Kumar
Sent: Monday, May 28, 2007 5:07 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MySQL Database Feature Source Cordiante System
Hi All,
I have successfully established connection of MySQL 5.0 Database and
mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but when
creating Layer using this data source then layer is not showing in autodesk
Layer Preview window, I think this is happning due to cordinate system, If i
am right then where is option of providing cordinate system of MySQL data
source ? If i am wrong then please give me idea, How to solve this problem ?
Regards,
Dhirendra Kumar
View this message in context:
http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
827380s16610.html#a10834515
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
