[mapguide-users] Unmanaged SHP File Locations
Zak James zak4ms at gmail.com
Mon May 28 16:17:25 EDT 2007
Andy,
I could be completely wrong about this, but I think that when you call
Open() on the feature source, it creates an XML configuration for all
the data in the feature source on the fly. In that case, it wouldn't
matter that your layer only references a single class, there is some
overhead to having all those shapefiles. It also looks like having
shapefiles in different projections within one feature source could
make things worse as it has to reproject them to figure out the
overall extents.
I'm going to do some experiments to see if I can see the same problems
- you've definitely got me interested... and maybe someone who knows
more about FDO will make some comment and educate all of us :)
zak
On 5/25/07, Andy Morsell <amorsell at spatialgis.com> wrote:
> Zak,
> In this case, I loaded the exact some files into the repository (managed)
> that I had in the unmanaged directory to see the differences in performance.
> So the performance difference must be attributed to something internal to
> MapGuide / FDO.
> Pointing at a directory of shapefiles is done at the unmanaged data source
> alias configuration level in webconfig.ini.  When you create a layer, that
> layer still only references one feature class (one shape file) from within
> that directory so there should be no reason for the provider to do extra
> work when accessing layers for a map render since it knows what exact shape
> file to access.  So there's something else going on here........ Sure, when
> you are first defining a layer, it must enumerate all shape files in a
> directory so you can choose which feature source to use, but that's a one
> time only thing.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zak James
> Sent: Friday, May 25, 2007 5:39 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Unmanaged SHP File Locations
> There may be efficiencies to be gained in the provider, but there are some
> limitations that don't have easy solutions.
> There are no attribute indexes for shapefiles so a lookup in a large file is
> going to be slow.
> Pointing at a directory of shapefiles is like pointing at one big data
> source with many feature classes. It may be convenient during development,
> but for production you will want to reference specific shapefiles or at
> least break down the large directory into smaller sets. I'm pretty sure
> managed shapefile feature sources are one per directory.
> If an unmanaged shape feature source draws more slowly than a managed one,
> it's worth checking that the shx file is present and valid.
> zak
> > First, I love the unmanaged resource concept and will most likely
> > deploy most future MGOS applications this way.
> > But, similar to Chris' problems, I have discovered that displaying
> > tooltips from unmanaged shape files causes a much more significant
> > performance hit and delay.  In my case, I have a 150 MB parcel polygon
> > shape file for a county.  In the unmanaged case, each tooltip AJAX
> > fetch spikes the CPU with mgserver.exe at 100% for a couple of
> > seconds.  Doing the same with the exact same shape file in a managed
> > state (not converted to SDF at load time), the CPU will only hit 25% or
> less and responds much more quickly.
> > Further, I discovered that the more unmanaged data in a map, the
> > slower the tooltip response is for all layers.  For instance, if I add
> > another 7 or so layers (like streets, water bodies, etc) to the map,
> > when I float over a parcel polygon it can take up to 10 seconds for a
> > tooltip response during which time mgserver is cranking away.  So, I'm
> > not sure what it's doing at that point.  All of these additional
> > layers are all in the same unmanaged data source folder.
> > I went ahead and loaded all of the shape files into the repository and
> > created a duplicate map pointing to the new managed feature sources.
> > This map behaves fine with tooltip fetches consuming 25% of a single
> > CPU and very quick response time.  So, this seems to confirm that the
> > more unmanaged feature sources in a map (at least from the same
> > directory), the larger the performance hit and the slower the map responds
> to requests.
> > I have appended this information to the TRAC ticket that Chris started
> > earlier today.
> > Andy Morsell, P.E.
> > Spatial Integrators, Inc.
> > http://www.SpatialGIS.com
> >  ________________________________
> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
> > Gountanis
> > Sent: Friday, May 25, 2007 7:52 AM
> > To: 'MapGuide Users Mail List'
> > Subject: [mapguide-users] Unmanaged SHP File Locations
> > Importance: High
> > Why do unmanaged FeatureSources respond slower as more files get added
> > to the directory location? We have a FeatureSource called SHPDefualt
> > for example. The zooms take longer as well as other functions. It
> > seems when you query a Feature Source is does not hit the DBF you want
> > directly it seems to fiddle with everything in the unmanaged
> > directory. We love the concept of a folder that contains all SHP
> > files. One location is great for batch processes and great for editing
> > new layers. It is just simple for customers to understand. For sure
> > easier to back up and recreate. Will this always be a performance killer?
> > Is this a bug? Will this be fixed soon?
> > This really takes the complication out of knowing what the heck is
> > going on in the repository. Here is XML Example:
> > <?xml version="1.0" encoding="utf-8" ?>
> > <FeatureSource
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> > xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> > <Provider>OSGeo.SHP</Provider>
> > <Parameter>
> > <Name>DefaultFileLocation</Name>
> > <Value>C:\SHPFILES</Value>
> > </Parameter>
> > </FeatureSource>
> > Chris
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
Zak James
