[mapguide-users] Need Help
Hidekazu Shimaji hshimaji at ybb.ne.jp
Mon May 28 19:30:26 EDT 2007
What kind of fdo provider do you use?
An ODBC provider supports only points.
If you use any other providers, I think you can use polygons.
(See fdo documents for detail. Some of them support only 2D polygons.)
To craete polygons without programing, you have to use Autodesk Map 3D.
You can save drawn polygons on your database.
Regards,
Hidekazu
--- "Arq. Luis E. Marin M." <luismarin at simbiosisgroup.net> wrote:
> I need help to create a polygons from data base because when I connect my
> database and assign the geometry property into correct fields I only
> receive, a few points only, on the layer created based on this database, and
> I need create polygons based on points x,y,z from database not just the
> point I need the polygon conformed for the consecutives points. Sorry about
> my bad English and I hope you can help me guys!
> Regards
> maxx
> CEO
> Simbiosis Group Inc.
> +58-2129432453  CCS
> +58-4165207873  CCS
> +01-3109283934  USA
> *****REGULACIÔð DE USO DEL CORREO ELECTRÔðICO DE Simbiosis Group Inc. HACIA
> INTERNET*****
> La informaci¡¦ contenida en este correo electr¡¦ico y cualquier anexo puede
> ser de car¡¦ter confidencial y es propiedad de Simbiosis Group Inc. S¡¦o
> estâÂpermitido su uso, copia, transmisi¡¦, recepci¡¦ o distribuci¡¦ a
> personas debidamente autorizadas. Si usted recibi¡¦este correo por error por
> favor destrùØalo y/o elimine cualquier copia guardada en su sistema y
> notifique inmediatamente al remitente o a la direcci¡¦ de correo electr¡¦ica
> info at simbiosisgroup.net. Usted no debe utilizar la informaci¡¦ contenida
> para ningùÍ prop¡¦ito ni compartirla con otras personas.
> This e-mail, including any attached files, may contain confidential and
> privileged information for the sole use of the Simbiosis Group Inc.  Any
> review, use, distribution, or disclosure by others is strictly prohibited.
> If you are not the intended recipient (or authorized to receive information
> for the intended recipient), please contact the sender by reply
>  info at simbiosisgroup.net and delete all copies of this message.
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 5/28/2007
> 11:40 AM
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
