[mapguide-users] Newbie problem with Webserverextensions configuration
azpublic azpublic at bluewin.ch
Tue May 29 02:51:56 EDT 2007
Hi all !
I’ve been experimenting a little on my custom installation (pre-installed
version of Tomcat)  on Windows 2000 and here are my conclusions. I hope they
will help someone, someday
. It has been a real pain in the ***  :-).
I did not yet managed to deploy MGOS on a preinstalled Apache http server
but I managed to have the one that is distributed with the installer to work
with my own Tomcat Install.
Here’s what you should do
First I did a full installation of the executable package for Windows but I
didn’t choose the bundled/preconfigured installation. I chose the last
option available which installs EVERYTHING
Next I edited my http.conf as follow :
FastCgiConfig -idle-timeout 120 -minProcesses 1 -maxClassProcesses 4
-multiThreshold 100 -singleThreshold 100 -killInterval 600
FastCgiServer "E:/MAPGUIDE/WEB/php/php-cgi.exe" -processes 4 -idle-timeout
120 -initial-env PHP_FCGI_MAX_REQUESTS=500 -initial-env PHP_FCGI_CHILDREN=1
#Start PHP FastCGI config
ScriptAlias /php/ "E:/MAPGUIDE/WEB/php/"
<Directory "E:/MAPGUIDE/WEB/php">
    Options ExecCGI
    AddHandler fastcgi-script exe
</Directory>
Action application/x-httpd-php5 "/php/php-cgi.exe"
AddType application/x-httpd-php5 .php
#End PHP FastCGI Config
#Start PHP Config
#ScriptAlias /php/ "E:/MAPGUIDE/WEB/php/"
#Action application/x-httpd-php "/php/php-cgi.exe"
#AddType application/x-httpd-php .php
#End PHP Config
# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for
Java API.
ScriptAlias /mapguide/mapagent/mapagent.fcgi
"E:/MAPGUIDE/WEB/www/mapagent/mapagent.exe"
AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$
"E:/MAPGUIDE/WEB/www/mapviewerphp/$1$2"
Alias /mapguide/mapviewerajax
"E:/MAPGUIDE/WEB/www/mapviewerphp/ajaxviewer.php"
AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$
Alias /mapguide/mapviewerdwf
"E:/MAPGUIDE/WEB/www/mapviewerphp/dwfviewer.php"
# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
Redirect /mapguide/mapviewerajax/
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/
http://localhost:8008/mapguide/mapviewerjava/dwfviewer.jsp
Alias /mapguide "E:/MAPGUIDE/WEB/www/"
<Directory "E:/MAPGUIDE/WEB/www/">
  AllowOverride All
  Options All
  Order allow,deny
  Allow from all
# Restrict access via HTTP to webconfig.ini
<Files webconfig.ini>
  Order allow,deny
  Deny from all
</Files>
# FastCGI MapAgent config
# Regular CGI MapAgent
#  AddHandler cgi-script exe
  RewriteEngine on
  RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
</Directory>
# Load mod_jk module
# Update this path to match your modules location
LoadModule    jk_module  modules/mod_jk.so
# Declare the module for <IfModule directive> (remove this line on Apache
2.x)
# AddModule     mod_jk.c
# Where to find workers.properties
# Update this path to match your conf directory location (put
workers.properties next to httpd.conf)
JkWorkersFile "E:/MAPGUIDE/WEB/Apache2/conf/workers.properties"
# Where to put jk logs
# Update this path to match your logs directory location (put mod_jk.log
next to access_log)
JkLogFile     "E:/MAPGUIDE/WEB/Apache2/logs/mod_jk.log"
# Set the jk log level [debug/error/info]
JkLogLevel    info
# Select the log format
JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
# JkOptions indicate to send SSL KEY SIZE,
JkOptions     +ForwardKeySize +ForwardURICompat -ForwardDirectories
# JkRequestLogFormat set the request format
JkRequestLogFormat     "%w %V %T"
# Send everything for context /examples to worker named worker1 (ajp13)
JkMount  /mapguide/mapviewerjava/* worker1
JkMount /mapguide/javaviewersample/* worker1
As you will note I changed the install directory to a custom dir so be
careful to point to correct paths everywhere in the httpd.conf file
I also edited php.ini file and chaged  the extensions path (extension_dir =
"E:\MAPGUIDE\WEB\php\ext")  in there so that it would point to the correct
location.
Next I registered the bundled Apache Http as a service with the following
command in the console
"E:\MAPGUIDE\WEB\Apache2\bin\apache" -k install -n "Apache2"
Now if you’re correct you should already be able to test php and apache by
going to the following page : HYPERLINK
"http://localhost:8008/mapguide/mapadmin/login.php"http://localhost:8008/map
If you manage to login, you’re on good tracks ^^
Install the GDAL patch MapGuide1.1.0_GDAL_Patch.zip
Here comes the tricky part :  THE Tomcat configuration
Just do a simple test to see that jk_mod forwards correctly to tomcat :
Add the following at the end of httpd.conf of Apache :
JkMount  /tomcat-docs/* worker1
Start tomcat and Apache
Test the following url HYPERLINK
"http://localhost:8008/tomcat-docs/"http://localhost:8008/tomcat-docs/
You should see a tomcat page  ---> Jk_mod is working properly
Create the mapguide.xml configuration file in
<tomcat-home>/conf/catalina/localhost as suggested in the documentation and
make it point to your www directory
Next go to the original  mapguide tomcat BIN dir ( in my example
E:\MAPGUIDE\WEB\Tomcat\bin )
Copy all the files that are in there inside the BIN directory of the Tomcat
install you want to run mapguide (I have chosen E:\TOMCAT\bin)
NOTE THAT THIS WAS FOR MY TOMCAT 5.5 Install so BE CAREFUL with other
versions of Tomcat.
Now start mapguide, tomcat and then apache
Test HYPERLINK
"http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?WEBLAYOUT=Libra
ry://ATest.WebLayout"http://localhost:8008/mapguide/mapviewerjava/ajaxviewer
.jsp?WEBLAYOUT=Library://ATest.WebLayout
You should get the following message :
Resource was not found: Library://ATest.WebLayout
This means that you succeded  :-)
What took me so much time was to notice that there were some extra file in
that tomcat BIN directory !!
Also, I didn’t manage to have my own Apache HTTP install.
I’m having some FastCGI problems.  I tried with Apache 2.2 but fastCGI has
to be patched to work properly and I didn’t manage to get it working
properly.
I also tried on Apache 2.0. I almost managed to get it working but also had
some Fast CGI problems mainly communication problems with timeouts.
So if anyone has a clue on how to get MGOS to work with a custom Apache 2.0
or 2.2 install just let me know.
I’ll probably write a guide for this kind of installations because it can
most certainly be useful in production environments.
I hope this helps .
CHEERS ^^
Alex
   _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: lundi, 14. mai 2007 17:49
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Newbie problem
withWebserverextensionsconfiguration
It sounds like you are using a pre-installed version of Apache and Tomcat.
The easiest way to configure this is to do a full, bundled
MGOS/Apache/Tomcat install and then copy the configuration from httpd.conf
to yours.  Here is mine and I hope it helps (change your paths as
appropriate).  If I remember correctly, there was a bug in the original ajax
redirect statement.
#-----------------Start MapGuide Enterprise Java web extensions config
ScriptAlias /mapguide/mapagent/mapagent.fcgi "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/mapagent/MapAg
ent.exe"
AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$ "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/mapviewerphp/$
1$2"
Alias /mapguide/mapviewerajax "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/mapviewerphp/a
jaxviewer.jsp"
AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$ "C:/Program
1$2"
Alias /mapguide/mapviewerdwf "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/mapviewerphp/d
wfviewer.jsp"
Alias /mapguide "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/"
<Directory "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/">
 AllowOverride All
 Options All
 Order allow,deny
 Allow from all
 AddHandler cgi-script .exe
 RewriteEngine on
</Directory>
Alias /PhpViewerSample "C:/Program
Files/Autodesk/MapGuideEnterprise2007/WebServerExtensions/www/PhpViewerSampl
e/"
#-----------------End MapGuide Enterprise Java web extensions config
#-----------------Start Tomcat connector support
JkWorkersFile "C:/Program Files/Apache
Group/Apache2/conf/workers.properties"
JkLogFile "C:/Program Files/Apache Group/Apache2/logs/mod_jk.log"
JkLogLevel info
# worker1 (ajp13)
Redirect /mapguide/mapviewerajax/ HYPERLINK
"http://127.0.0.1/mapguide/mapviewerjava/ajaxviewer.jsp"http://127.0.0.1/map
Redirect /mapguide/mapviewerdwf/ HYPERLINK
"http://127.0.0.1/mapguide/mapviewerjava/dwfviewer.jsp"http://127.0.0.1/mapg
#-----------------End Tomcat connector support
#-----------------Start MapGuide Java sample support
#-----------------End MapGuide Java sample support
Andy Morsell, P.E.
Spatial Integrators, Inc.
HYPERLINK "http://www.SpatialGIS.com"http://www.SpatialGIS.com
   _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of azpublic
Sent: Sunday, May 13, 2007 12:47 PM
Subject: RE: [mapguide-users] Newbie problem with
Ok I’ve been installing a reinstalling MapGuide these past two days but I
still cant have any chance in getting the Apache to render the JSP’s
correctly
I’ve been trying to copy MapGuideApi.jar in CATALINA_HOME\common\lib, in
CATALINA_HOME\server\lib, in CATALINA_HOME\shared\lib,. Nothing to do
I’ve also tried to copy  the library in JAVA_HOME\\lib\ext\
 no result
I tried adding "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\WEB-INF\lib"; to my
classpath .. no result
I always get this stupid error from tomcat when requesting
HYPERLINK
as suggested in the InstallConfigureMgOpenSourceOnWindows.pdf documentation.
Here is the complete error returned by my Tomcat 5.5.17  the first time I
hit the url above :
exception
org.apache.jasper.JasperException: no MapGuideJavaApi in java.library.path
org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWra
pper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:3
75)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
        org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
cause mère
javax.servlet.ServletException: no MapGuideJavaApi in java.library.path
org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextI
mpl.java:858)
org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImp
l.java:791)
org.apache.jsp.mapviewerjava.ajaxviewer_jsp._jspService(ajaxviewer_jsp.java:
885)
        org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
32)
cause mère
java.lang.UnsatisfiedLinkError: no MapGuideJavaApi in java.library.path
        java.lang.ClassLoader.loadLibrary(Unknown Source)
        java.lang.Runtime.loadLibrary0(Unknown Source)
        java.lang.System.loadLibrary(Unknown Source)
org.osgeo.mapguide.MapGuideJavaApiJNI.<clinit>(MapGuideJavaApiJNI.java:2095)
org.osgeo.mapguide.MapGuideJavaApi.MgInitializeWebTier(MapGuideJavaApi.java:
14)
org.apache.jsp.mapviewerjava.ajaxviewer_jsp.InitializeWebTier(ajaxviewer_jsp
.java:36)
org.apache.jsp.mapviewerjava.ajaxviewer_jsp.GenerateMainPage(ajaxviewer_jsp.
java:173)
876)
32)
note La trace complète de la cause mère de cette erreur est disponible dans
les fichiers journaux de Apache Tomcat/5.5.17.
And Here is the error returned by tomcat if I try to refresh the page :
exception
pper.java:510)
75)
cause mère
mpl.java:858)
l.java:791)
885)
32)
cause mère
java.lang.NoClassDefFoundError
14)
.java:36)
java:173)
876)
32)
If someone reads this message please help !  you’re my only hope :-)
   _____
Sent: samedi, 12. mai 2007 10:20
Subject: RE: [mapguide-users] Newbie problem with Web
Ok  I managed to get something after struggling with httpd.conf. I am now
pretty sure that I managed to communicate with my Tomcat install however I
still have some error  :
I encountered a http 500 error when trying to access
http://localhost:8008/mapguide/mapviewerjava/ajaxviewer.jsp?WEBLAYOUT=Librar
y://ATest.WebLayout :
It seems that Tomcat is not able to find the three jars located in
www/WEB-INF/lib/ of the MapGuide Installation ?
Any idea how I can fix this ?
Thanks in advance :-)
Cheers
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.467 / Virus Database: 269.6.8/797 - Release Date: 10.05.2007
17:10
No virus found in this incoming message.
17:10
Version: 7.5.467 / Virus Database: 269.6.8/800 - Release Date: 11.05.2007
19:34
19:34
Version: 7.5.467 / Virus Database: 269.7.0/801 - Release Date: 12.05.2007
18:40
Version: 7.5.467 / Virus Database: 269.7.0/803 - Release Date: 13.05.2007
12:17
Version: 7.5.472 / Virus Database: 269.8.1/822 - Release Date: 28.05.2007
11:40
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070529/c98e9a57/attachment.html
