[mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue May 29 08:05:43 EDT 2007
Yes, we've successfully compiled / tested MG on Fedora Core 4 using gcc
4.0.2.  Version 4.1.2 also works.
Glad you got it working.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Audaire
David
Sent: Tuesday, May 29, 2007 2:00 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide 1.1.0 Linux Fedora Core 4 Install
Well i am now capable to run mgserver i think my last install is the
good
one! i think that the main difference is the gcc version 4.0.2. the
first
time i made a wrong install of the gcc so ./configure use the 4gcc 4.0.0
version. I am really new to linux and i think the gcc installation was
the
most difficult step in the install process.
Audaire David wrote:
> Hi,
> When installing FDO Components i use the ./build_thirdparty.sh comand,
and
> it returns few warning the fisrt one is Underquoted definition of
> FDO_SUBST  and  then following others underquoted definition FDO_....
> am i expected to do something??
> By the way it's the second time i try to install MGOS on Fedora, the
first
> time i wasn't abble to run mgserver, and i wasn't able  to find a log
in
> directory and a message on screen, is there a place to look for
> informations in the linux system logs elsewhere ????. This time i
install
> the debug version i hope i will be able to find more information if it
> doesn't run.
> Thank you for any suggestion
View this message in context:
http://www.nabble.com/Mapguide-1.1.0-Linux-Fedora-Core-4-Install-tf38271
72s16610.html#a10852636
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
