[mapguide-users] Unmanaged SHP File Locations
Chris Gountanis cgountanis at mpower-tech.com
Wed May 30 10:11:30 EDT 2007
I am also available to test if needed.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Tuesday, May 29, 2007 6:50 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Unmanaged SHP File Locations
On second thought...
By turning on connection pooling for the SHP provider, the server will
cache the connection so the next time it is accessed, things should be
quick.  However, the cached connection gets purged every 10 minutes
(default) or so, so if the connection has been removed from the cache,
the next person to access the resource will still have to wait... hmmm,
sounds like we should still investigate the root problem of the
slowness.
Tom
Fukushima
Sent: Tuesday, May 29, 2007 5:38 PM
Andy, do you have connection pooling for the SHP provider turned on?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, May 29, 2007 5:18 PM
Perhaps we could somehow cache the schema description?
Jason
In the current architecture, config docs are attached to feature
sources; putting them with layers will require some non-trivial changes
and seems hacky to me. I think that looking into whether the performance
of the SHP provider on folders can be improved or not is the first thing
we should do.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
