[mapguide-users] RE: MapGuide Automated Tiling Engine
MaciekS msiedlaczek at techmex.com.pl
Wed May 30 10:21:17 EDT 2007
Dear Kori.
Yesterday, after you gave me a tip how to use T.E., i generated lot of
tiles. It works fine!
Now I'm wondering how to use parameters sx, sy, ex, ey to reduce generating
of empty tiles.
What are criteria of using these parameters?
Regards, Maciek
Kori Maleski-3 wrote:
> Hi Maciek,
> This looks like an issue with the DLLs.
> Can you please detail where your installation of MapGuide is ( C, D or
> other
> drive), and if you are running the TilingEngine from its default
> installation folder?
> Please try the following:
> Backup the Tiling Engine folder.
> Copy the contents of your C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin folder
> to
> Copy the file C:\Program Files\MapGuideOpenSource\WebServerExtensions\www\
> webconfig.ini to the folder.
> Then try running the exe from the command line again.
> Let me know whether the issue persists.
> Cheers,
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MaciekS
> Sent: Monday, May 28, 2007 4:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MapGuide Automated Tiling Engine
> Hi everyone!
> I tried to use tiling engine - fmtilingengine
> Unfortunatelly with no results. May you help me, what did I wrong?
> I called program: fmtilingengine -u Administrator -p *** -m 1014Tile
> My Error log:
> Title: Error
> Message: Failed to retrieve message for "MgFileNotFoundException".
> StackTrace: Failed to retrieve message for "MgFileNotFoundException".
> Exception occured in method ByteSourceFileImpl.LoadFile at line 126 in
> file
> .\System\ByteSourceFileImpl.cpp
> Date/Time: 2007-05-29 00:33:05
> Title: Error
> file
> Date/Time: 2007-05-29 00:33:08
> Title: Error
> file
> Date/Time: 2007-05-29 00:33:09
> Regards, Maciek
> Hi everyone,
> Websoft Developers is pleased to announce the availability of our free
> MapGuide tiling utility.
> You may download the installation file from the following link:
> Http://www.websoftdev.com/download.cfm
> This is a command line utility that can be accessed via a windows console
> window or executed via a batch file.
> For those familiar with SDF Loader for MapGuide 6.5, this will be familiar
> territory.
> Note:
> 1) The application has been tested with .NET MapGuide extensions only.
> 2) The application works on the Windows platform only, with apologies to
> all
> the Linux users.
> 2) Replace MapGuide Open DLLs/webconfig.ini with MapGuide Enterprise
> DLLs/webconfig.ini for use with Enterprise.
> Please provide feedback for any bugs and application hangs, etc.
> If you have any difficulties downloading, wait till the end of Monday and
> try again.
> More details follow below.
> Enjoy!
>   _____
>  <http://www.websoftdev.com/>
> Kori Maleski
> F: (530) 759-0923
>  <mailto:kori.maleski at websoftdev.com> kori.maleski at websoftdev.com
>   _____
> FacilitiesMap Tiling Engine for MapGuide Open Source/Enterprise
> The Tiling Engine is a batch utility to be used with MapGuide tiled maps.
> Aim is to create a utility that will handle the pre-generation of tiled
> maps
> that utilize Base Layers.
> This utility is being made available for use to the MapGuide community.
> You are free to use it.
> Main features:
> *	Support for MapGuide Open/Enterprise
> *	Use of Command line parameters
> *	Configurable in a batch script for automated tiling
> *	Tile a specific map
> *	Tile a specific Base Layer Group
> *	Tile a specific Zoom Threshold
> *	Tile a specific Tile index by minimum/maximum
> *	Restrict Tiling by Authentication to a specific Map or resource
>  Version 0.1.0 :
> *	Support for MapGuide 1.1.0 , MapGuide Enterprise SP1
> *	.NET Only
> Testing Platform and versions:
> *	MapGuide Open 1.1.0, MapGuide Enterprise SP1
> *	Laptop: Windows XP SP2 P4 Duo Core 2GHz with 2G RAM
> *	Tested with .NET MapGuide Components Only.
> This is a work in progress; please direct any comments or concerns here:
> info at websoftdev.com
> FacilitiesMap Tiling Engine Instructions:
>             Accessing Help & Instructions
>                -h or -help                  Help Menu
>              Required Parameters:
>                -u or -user                  MapGuide UserName
>                -p or -password          MapGuide Password
> Optional Parameters:
>                -m or -map                 Specify a specific map by name
>                -g or -group                Specify a specific base layer
> group by name
>                -s or -scale                 Specify a specific finite
> scale
>                -sx                             Specify a starting tile
> column (x)
>                -sy                             Specify a starting tile row
> (y)
>                -ex                            Specify an end tile row (x)
>                -ey                            Specify an end tile row (y)
> Enable Log File:
>                -l or -log                     Verbose ouput to a log file
> Usage:
>                FmTilingEngine -u myUseName -p myPassword
> *          This will tile ALL maps accessible to this user
> *          This will tile ALL base layer groups accessible to this user
>                FmTilingEngine -u myUseName -p myPassword -m SheboyganTiled
> *          This will tile ONLY the map specified and accessible to this
> user
> The g, s, sx, sy, ex, ey parameters are available only when the m
> parameter
> - map name -
> is  specified.
> -g 'Base Layer Group'
> user
> *          This will tile ONLY the base layer groups accessible to this
> user
>                     -g 'Base Layer Group' -s 7196 -sx 2 -sy 2 -ex 15 -ey
> 20
> user.
> user
> *          This will tile ONLY the specified Scale
> *          This will tile ONLY the specified tile rows and columns
> *          Any combination of the sx, sy, ex, ey parameters may be
> specified.
> *          Defaulted to the starting and ending column/rows if left
> unspecified.
> Specifying Starting/Ending Row/Columns is specifically meant for
> generating
> tiles for an area
> subset in the case of a map finite scale requiring a significant amount of
> tiles.
> In general, the -m map, -g group will be the main options utilized.
> Be warned - tiling can be computationally intensive.  It is recommended
> that
> in the process be
> run on a development or staging machine, and the tile cache be copied to
> the
> production server
>  upon completion.  This will depend on your map extents and tile
> requirements.
> mapguide-users mailing list
> http://www.nabble.com/MapGuide-Automated-Tiling-Engine-tf3660489s16610.html#
> a10845534
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/MapGuide-Automated-Tiling-Engine-tf3660489s16610.html#a10874759
