[mapguide-users] MGE, Base layers and consistent scale ranges
Maksim Sestic max at geoinova.com
Sat Nov 3 12:07:58 EDT 2007
You should export map .xml definition file, correct scales by hand, then
re-import changed .xml file to the MG server using web tier test
application. I guess there's a change request for MG Studio regarding this
one.
Regards,
Maksim Sestic
ori gudes wrote:
> Dear Maksim
> Do you have any information about generating consistent set of scales?
> Cheers Ori
> Do you have any information of
> Maksim Sestic wrote:
>> Dear all,
>> I'm using MGE 2008 with MapGuide Studio 2008, and I'm new to Base Layers
>> concept.
>> I created one Base Layer with a raster Layer in it. Then I set the
>> nearest Zoom In (250), farthest Zoom Out (50000) and total number of
>> scales (10) parameters. End result is autogenerated set of scales. When
>> I run this map in Web browser I can zoom only to scales matching the ones
>> in BaseLayer's autogenerated scale list.
>> The question is - how do I change single scale in (auto)generated scale
>> list? I.e. I want to have consistent, geodetic set of scales as in 100,
>> 250, 500, 1000, 1500, 2000, 2500, ... 50000. Is it doable with MGS at
>> all?
>> With kindest regards,
>> Maksim Sestic
View this message in context: http://www.nabble.com/MGE%2C-Base-layers-and-consistent-scale-ranges-tf4520911s16610.html#a13564159
