[mapguide-users] Adding marker on the fly with tooltip
Jackie Ng jackie.ng at aecsystems.com.au
Sun Nov 11 22:51:20 EST 2007
Did you put the tooltip tag in the right location? The <ToolTip> tag usually
follows the <Geometry> tag in a layer definition document.
- Jackie
Kencana wrote:
> Hi,
> Can we modify the markersymbol.templ file to add <ToolTip></ToolTip> tag
> into it?
> I have try to add it but it returns me such error message.
> ERROR: The new XML document is invalid.
> .PHP Warning: Element W2D content check failure in C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\CAN MAP
> Files\layer_functions.php on line 27 PHP Fatal error: Call to a member
> function SetGroup() on a non-object in C:\Program
> Files\layer_functions.php on line 66
> any idea on how i can make it work?
> Thank you
> Regards,
> Kencana Kesuma
View this message in context: http://www.nabble.com/Adding-marker-on-the-fly-with-tooltip-tf4788633s16610.html#a13699339
