Re[mapguide-users] freshing a map/layer... from server side, avoiding JavaScript
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Nov 12 03:25:22 EST 2007
It sounds as if you want to do a "server push" rather than the more
common "client pull".
I'm not sure that it is easily accomplished, but since the AJAX viewer
contains a lot of JS code, I don't see any problems in an extra refresh
call.
Regards, Kenneth, GEOGRAF A/S
Zac Spitzer skrev:
> I'm pretty sure your going to need to use javascript. The mapguide
> javascript API
> is pretty solid and mature, if you check the archive of this newsgroup
> there are
> not many posts i can remember where people are having issues with
> consistency
> between browser implementations.
> Use the recommended approach, it's documented and supported. Any other
> approach,
> will most likely cause headaches down the track as mapguide evolves.
> What are the security reasons?
> z
> On Nov 10, 2007 10:18 PM, Maksim Sestic <max at geoinova.com
> <mailto:max at geoinova.com>> wrote:
>     I'm writing some server app that imposes occasional changes to certain
>     layers, based on data collected in real time. Therefor, it requires
>     layer/map refresh initiated by server-side application. Since it's
>     fully
>     written in ASP.NET <http://ASP.NET> (Ajax.NET) utilizing web
>     services+events, I'm trying to
>     avoid JavaScript as much as possible due to consistency and security
>     reasons.
>     I guess it's presently not possible to issue a refresh on
>     map/layer without
>     calling JavaScript function from client side. Is there any
>     workaround to
>     this?
>     Regards,
>     Maksim Sestic
>     View this message in context:
>     http://www.nabble.com/Refreshing-a-map-layer...-from-server-side%2C-avoiding-JavaScript-tf4782233s16610.html#a13681172
>     Sent from the MapGuide Users mailing list archive at Nabble.com
>     <http://Nabble.com>.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> http://zacster.blogspot.com/
> +61 405 847 168 (aussie moible)
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071112/c8640850/attachment.html
