[mapguide-users] RenderingService and DPI (How to change DPI before rendering)
Scott Hameister scotth at mpower-tech.com
Mon Nov 12 12:59:41 EST 2007
How do I change the DPI that The  Rendering Service Uses when Creating a
map.
The Streamed Image from the rendering service is being poured into a PDF
file.the problem is that the quality of the PDF varies based on the
Resolution my Screen is at when I render the Stream, instead of being
consistent in the PDF. If I'm at 1024 x 768 the PDF map is grainier than if
I'm at 1920x1200 resolution when  I stream the image How can I address this
to make the PDF quality the same for all users?
<cfset newMap =
renderingSrvc.rendermap(map,mgselection,realCenter,Javacast("DOUBLE",SesMapS
cale),Javacast
("INT",SesScrnW),Javacast("INT",SesScrnH),mapcolor,"PNG")>
Above Is my Coldfusion call.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071112/8af813b8/attachment.html
