[mapguide-users] Application develop environment
Gunter Becker gunter.becker at CSOGIS.DE
Wed Nov 14 06:10:55 EST 2007
I found out that my application works when I put the error throwing code in
try-catch blocks. Every time I put another piece of code into a try-catch
block there is another error message which begin with "Failed to retrieve
message for ...". It seems that the error isn't critical for the application
and only belongs to haven't access to the file that stores the error
messages.
So, I suppose that MapGuide couldn't find the ResourcesPath in the
webconfig.ini. Is someone out there who agree with me? Like I've said in my
previous message I don't know if it must be an absoulte path or an UNC-Path.
Could it be that it doesn't work at all.
Maybe the correct develop environment is like that:
First machine: Webapplication + MapGuide WebExtensions
Second machine: MapGuide Server
I've seen a similar post in the Autodesk Discussion Group that discribes the
same problem but also with no solution:
http://discussion.autodesk.com/thread.jspa?messageID=5622633
MgInitializeWebTier - crashes
I can't believe that there is no one out there who have webapplication and
MapGuideOpenSource installed on different computers. There must be someone.
I think it doesn't make sense to have all application on the same machine
with regard to load balancing and performance.
Gunter
View this message in context: http://www.nabble.com/Application-develop-environment-tf4796625s16610.html#a13744430
