[mapguide-users] WMS-client
Jason Birch Jason.Birch at nanaimo.ca
Tue Nov 20 18:07:50 EST 2007
What you need is a configuration document for the WMS data connection.
However, the documentation on this is somewhat complicated, and there is no easy way of creating the configuration document.
There is some history/information on this in the fdo-users archive:
http://tinyurl.com/24dll8 <http://tinyurl.com/24dll8>
And you can see some samples of these config documents in the FDO unit tests, for instance:
http://tinyurl.com/2aee8l <http://tinyurl.com/2aee8l>
(I think that this may also be the answer to Susan's question... perhaps her WMS are not transparent...)
Jason
Subject: [mapguide-users] WMS-client
I added a wms layer to my map.Now I need the layer more configure, for
example change EPSG,format..
Where shall I do it ?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071120/0ef44d4f/attachment.bin
