[mapguide-users] Mapguide V 2.0
Chris Tallman ctallman at innomap.com
Wed Nov 28 15:02:18 EST 2007
Well I was to fast to the email on this one.  I still have some problems
but I'm not sure they are Mapguide Related.
I can get to the login page now. However when I type in the username and
password I get a 403.1 Forbidden: Execute access is denied error.
Pertaining to ISAPI and CGI.  I have to figure out what setting to
change or add to get past this.
All the directories say scripts and executables so I'm not sure what the
hang up is.
If anyone has any ideas I'm listening.
Thanks,
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Wednesday, November 28, 2007 2:36 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Mapguide V 2.0
That was what I might have miss understood what Dave was talking about.
I added .php with the two files to the Web Service Extensions list and
now it works.
Is this an item that should be added to the trac list to make sure it
gets fixed in the next release?
Thanks for the help.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of IT-Joe
Marvin
Sent: Wednesday, November 28, 2007 2:29 PM
Did you check to see if the IIS6 Web Server Extensions is blocking the
PHP?  Maybe flip on the allow all ISAPI extensions to see if it is
blocking it.
-joe
Tallman
Sent: Wednesday, November 28, 2007 11:23 AM
Yep I'm using Windows 2003.
After the install I have .php set to php5isapi.dll. for the Mapguide VD.
This is how it was and it doesn't work.
After your email I added .php set to php-cgi.exe for the mapagent VD.
This doesn't seem to fix the issue.
Why am I adding a php ref to the mapagent directory when the admin is in
the mapadmin folder which in my case after installation isn't a Virtual
Directory(VD)
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, November 28, 2007 12:58 PM
What platform are you installing on?
It's likely under IIS6 (Windows 2003) that the web extension for PHP is
missing. I have added an entry for the phpisapi5.dll and the
php-cgi.exe.
Regardless of your install platform, under the mapagent virtual
directory configuration add .php as an extension and point it to the
php-cgi.exe.
Note if you check the configuration under mapguide to ensure that .php
is pointing to the isapi dll you may get prompted to propagate a script
setting to the mapagent directory. DON'T select the mapagent directory
and let it propagate, just lick ok.
Regards,
Dave
Tallman
Sent: Wednesday, November 28, 2007 10:22 AM
Subject: [mapguide-users] Mapguide V 2.0
Has anyone else had an issue with the bundled IIS .NET install and the
mapadmin login?  For some reason or another the php pages don't want to
load.  I've installed on a computer where MapGuide has worked before and
have also tried the install on a fresh system.
I've been able to check the mapagent index.html page and everything
works fine there, so something is up with the php parts.
So is there a step I'm leaving out?  Has this been an issue for anyone
else?  Can anyone give me a tip on making this work?
Thanks,
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071128/9c56e591/attachment.html
