[mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Jo Cook j.cook at OXFORDARCH.CO.UK
Fri Nov 30 06:38:43 EST 2007
Hi Jason,
I tried to apply your patch and it didn't work (it said it was garbage!) but
I made the changes to the makefile.am and it all seemed to install. However,
I immediately screeched to a halt when I tried to make a postgis data
connection and got the error:
An exception occurred in FDO component
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 262 in file
Fdo.ConnectionManager.cpp
Have you had any success with the postgis data connector on Ubuntu?
Thanks for all your help
Jo
JasonBirch wrote:
> Hmm.  Maybe I'll max mine out and see if I can get a faster build :)
> I've attached a .patch to the ticket that will fix the Makefile.am with
> these changes.
> http://trac.osgeo.org/mapguide/ticket/347
> The easiest way to apply this patch (and others from Trac):
>  sudo apt-get install curl
>  cd ~/mgsvn/Web/src/CgiAgent
>  curl
> http://trac.osgeo.org/mapguide/attachment/ticket/347/CgiAgent_Makefile.a
> m.patch?format=raw | patch
> Then you just go back to the ~/mgsvn and start again from "Go for the
> gusto".  Note, I haven't actually tried this without cleaning up
> first... not sure how the automake/autoconf thing deals with modified
> makefiles.
> Some other tools that are useful:
>  sudo apt-get install subversion-tools
> Running svn-clean will remove any files that are not under version
> control, so it cleans up nicely after a build.  Before running a clean
> build, I clear out the /usr/local/ fdo and mapguide directories, run
> svn-clean on ~/fdosvn and ~/mgsvn, and then do an svn update.
> Jason
> -----Original Message-----
> From: Jo Cook
> Subject: RE: [mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
> Great, I'll give it a try. I managed to speed it up by doubling the
> amount of RAM my VM was trying to use, and that did seem to help. Worth
> knowing in future...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MGOS-2-build-freezing-on-Ubuntu-7.10-tf4881293s16610.html#a14042562
