[mapguide-users] ArcSDE 9.2 and MapGuide 1.2
Bruce Dechant bruce.dechant at autodesk.com
Fri Nov 30 11:56:38 EST 2007
The following steps should help:
1)      Stop the MGE2008 server service by opening the "Services" applet from the Administration tools and stopping the service named "MapGuide Enterprise 2008 Server"
2)      Make a backup copy of the C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\Bin\Fdo directory in case you need to revert the FDO update.
3)      Install the updated FDO 3.2.3 in the C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\Bin\Fdo directory
4)      Restart the service named "MapGuide Enterprise 2008 Server" from the same "Services" applet mentioned above.
5)      The MapGuide server will now be using the updated FDO.
Thanks,
Bruce
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Remigijus Brazys
Sent: Friday, November 30, 2007 5:18 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] ArcSDE 9.2 and MapGuide 1.2
Hi all,
I have a user who uses ArcSDE 9.2 server to store his data, and also he has AutoCAD Map 2008 and Autodesk MapGuide Studio 2008 with our solution based on MapGuide 1.2. When I'm trying to connect to there's data store with Autodesk MapGuideStudio 2008 i'v got en error ....
I see that new opensource FDO (http://fdo.osgeo.org/downloads.html)3.2.3 version can support ArcSDE 9.2, I dawnloded it but how to use it with Autodesk MapGuide Studio 2008 .... ? Or maybe you can point me how to connect to9.2 ArcSDE database
Thanks.
Best regards,
Remigijus Brazys
GIS analyst, InfoEra
______________________________________________
Phone.: +370 5 2788456
Fax.: +370 5 2784723
Mobile.: +370 656 10089
S.Zukausko str. 17
LT-08234, Vilnius, Lithuania
E-mail: remigijus at infoera.lt<mailto:sonata at infoera.lt>
www.infoera.lt<http://www.infoera.lt/>; www.gps.lt<http://www.gps.lt/>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/4d3e561f/attachment.html
