[mapguide-users] Java error in script - runs fine from studio
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Oct 1 14:52:16 EDT 2007
I can't tell you excatly what is wrong, but you should refer to the
Developers guide for an explanation of the frame setup.
I belive the problem that you have is that the call
"parent.parent.mapFrame" does not give you the map frame.
I would recommend that you install FireBug for Firefox.
The FireBug plugin makes it possible to step into the code and examine
the variables/objects in use.
If you MUST use IE, you can configure Script Debugging for IE, and have
Visual Studio capture and debug the errors.
Regards, Kenneth, GEOGRAF A/S
nicolej skrev:
> Ok I'm not sure what you mean by frame set but this my default page I
> used and old sample script.
> ListLanguages.php and zoomSelectLanguage.php are the scripts running
> the got to language feature
> The map works without fail every time through studio or without using
> my default.php page.
> Thanks for the help
> NJ
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071001/97bc0582/attachment.html
