[mapguide-users] RE: MySQL and Mapguide Studio
emviado emmanuelviado at yahoo.com
Tue Oct 2 11:56:01 EDT 2007
Hi!
You may have already solved the problem. If not, I hope this helps. My
mapguide studio FDO connection to mysql 5 was alright until I installed a
mysql GUI client that installed a libmysql.dll in C:\windows\system32. I
just renamed it and my FDO connection came back.
emviado
Chris Gountanis wrote:
> Did you try coping the libmySQL.dll to the studio/server FDO folders and
> installing the MySQL ODBC driver? Not sure if the ODBC driver is needed
> but
> when I copied the libmySQL.dll to the FDO folders on both Studio and
> Server
> everything worked.
> On a side note:
> If you want to get fancy you can always have a central place for your FDP
> and use the server config file to point to that location. For example I
> have
> Map, Studio and Server all using the same FDOs.
> Chris Gountanis
> Programmer/Analyst - Network Administrator
> cgountanis at mpower-tech.com
> T: 877-269-6971 | T: 920-830-4053 | F: 920-832-0736
> MPOWER TECHNOLOGIES
> 501 S Nicolet Road Appleton, WI 54914
> www.mpower-tech.com
> Making complex information more accessible.
> -----Original Message-----
> From: George McLean [mailto:gmclean at gorge.net]
> Sent: Wednesday, August 23, 2006 6:20 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] MySQL and Mapguide Studio
> I am just getting started with MapGuide Studio and am trying to add an FDO
> feature source stored in MySQL 5.0.18-nt on WinXP sp2.
> I can query the FDO data store through Autodesk Map 2007 so I think that
> is
> OK.
> When I am in Mapguide Studio configuring the MySQL connection I get the
> following error when I try to browse for a data store:
> "No MySQL client installed"
> I am using the user 'root' with a password that I know works.
> I have moved the libmySQL.dll to C:\Program Files\Autodesk Map 3D
> 2007\FDO\bin where the FdoMySql.dll resides. I have also added the path
> the
> libmySQL.dll to the PATH environment variable.
> Any suggestions on how to make this work?
> Thanks
> George McLean
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/MySQL-and-Mapguide-Studio-tf2155587s16610.html#a13001592
