[mapguide-users] Exmple of Gdal index xml
Thu Oct 4 16:01:29 EDT 2007
Gary Morin wrote:
> I've corrected the bounds, one of the images did not upload correctly, as to
> the truncated file, it's probably finger troubles by me.
> Attached is a new version, which still gives the same error.
Gary,
This still seems truncated.  In particular it ends with a </Feature>
but it should end with </DataStore>
eg.
<!-- Sample configuration file for Raster File Provider DataStore that contains
satellite photos -->
<DataStore xmlns:fdo="http://www.autodesk.com/isd/fdo"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns="http://www.autodesk.com/isd/fdo"
xsi:schemaLocation="http://www.autodesk.com/isd/fdo
  FdoDocument.xsd">
... a bunch of schema stuff...
   </xs:schema>
   <!-- Schema Overrides for Photos Feature Schema -->
   <SchemaMapping name="photos" provider="OSGeo.Gdal.3.0"
xmlns="http://www.autodesk.com/isd/fdo/RasterFileProvider">
     <!-- Schema Overrides for Photo Feature Class -->
     <complexType name="PhotoType">
       <RasterDefinition name="photos">
         <Location name="/home/warmerda">
           <Feature name="Airport2">
             <band name="RGB" number="1">
               <Image name="utm.tif">
               </Image>
             </band>
           </Feature>
           <Feature name="Airport">
                 <Georeference>
                   <InsertionPointX>200000.000000</InsertionPointX>
                   <InsertionPointY>1000000.000000</InsertionPointY>
                   <ResolutionX>1</ResolutionX>
                   <ResolutionY>1</ResolutionY>
                   <RotationX>0</RotationX>
                   <RotationY>0</RotationY>
                 </Georeference>
               </Image>
             </band>
           </Feature>
         </Location>
       </RasterDefinition>
     </complexType>
   </SchemaMapping>
</DataStore>
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
