[mapguide-users] How to get an auto-generatedIdafterInsertFeature ?
Dave Wilson dave.wilson at autodesk.com
Tue Oct 9 16:43:57 EDT 2007
A point definitely worth considering, but if you are inserting into an
SHP or an SDF you shouldn't expect concurrent users as you need an
exclusive lock on the file to do the write if I am not mistaken. If you
have multiple users attempting to write to the same SDF or SHP you will
likely experience problems including the example you show.
Of course with a database this should be a non-issue.
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, October 09, 2007 12:34 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] How to get an
I think that this might cause problems in high-concurrency situations:
user a: selects max ID (23)
user b: selects max ID (23)
users a and b insert features
user a: selects max ID (25)
user b: selects max ID (25)
Jason
Subject: RE: [mapguide-users] How to get an auto-generated
Another approach might be to select the Max Id before the insert and
select the Max Id after the insert. I don't believe the Id's get
assigned such that they will use existing gaps (from deleted features)
so the new Id should always be higher correct?
Dave
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
