[mapguide-users] MapGuide Automated Tiling Engine 1.2 -patchedrelease
Kori Maleski kori.maleski at gmail.com
Mon Oct 15 01:33:17 EDT 2007
Hold off trying to change the parameters.
I will see if I can replicate the issue and post a fix tomorrow.
It seems to be an issue with the map extents/tilecount.
Kori Maleski
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Krunoslav
Sent: October 14, 2007 10:22 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] MapGuide Automated Tiling Engine 1.2
-patchedrelease
Kori Maleski-4 wrote:
> Are the scales you are using the same as in the Map Definition in Studio?
> If you run it without specify a scale does it throw the same errors?
Of course they are the same: I am running it without any parameter:
C:\Program Files\Websoft Developers\FacilitiesMap Tiling
Engine>FmTilingEngine.e
xe -u Administrator -p admin
Preparing to Tile 'map1' Map Definition...
Initializing Connection to MapGuide...Succeeded
Tiling 'Orto' Layer Group...
 Scale: 1:5000   Finite Scale 1 of 3
 Tiles: 9 ( 3 Columns x 3 Rows )
 ...1...2...3...4...5...6...7...8...9                   100%
 Scale: 1:2000   Finite Scale 2 of 3
 Scale: 1:1000   Finite Scale 3 of 3
Tiling Complete
But, as I wrotebefore, tiles are not being made due to Errors. Should I try
to change some parameters regarding tile size and format in
serverconfig.ini?
View this message in context:
http://www.nabble.com/MapGuide-Automated-Tiling-Engine-1.2---patched-release
-tf4616105s16610.html#a13206887
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
