[mapguide-users] duplicate labels
Traian Stanev traian.stanev at autodesk.com
Wed Oct 17 13:55:45 EDT 2007
If you have long polylines, they may get labeled several times with a
spacing of a few hundred pixels between labels. May be this is what you
are seeing.
Inverted labels should be rare -- only if you have circular or nearly
circular polylines in your layer. Even then the code in 1.2 will try to
avoid that as much as possible. Since labels follow the curve of the
polylines, it can happen that one piece of the label is pointing up
while another is pointing down. Again, I'm just guessing here since you
did not give enough detail.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of AJim
> Sent: Wednesday, October 17, 2007 1:17 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] duplicate labels
> Hi,
> Newbie trying to use 1.2 with street maps.  We seem to be getting
> duplicate
> labels and upside down labels displayed.  The source was imported from
> a
> shapefile.  Not using any tiling features.
> Any ideas?
> Thanks
> AJ
> View this message in context: http://www.nabble.com/duplicate-labels-
> tf4630604s16610.html#a13222479
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
